I've had problem's with my bike pump cutting out mid journey , and had to revert back to mechanical pump, would anyone foresee
problem's if i ran both pump's at same time, do bike carb's have a float system to shut of the flow of fuel.
Cheer's Brad.
would anyone foresee problem's if i ran both pump's at same time,
The only problem with a scrapper (presumably car) pump would be that bike carbs like bike pumps (all to do with different pressure / flow rates). You might find things got worse by using a car pump (might not though!!)...
the car does seem to run better with bike pump , but i thought if i leave car pump connected as well , it would act as a back up.
When the bike pump cuts out, does the car cut out too?
The bike pump is supposed to sense pressure and stop, then restart when it needs to.
No reason why the bike pump shouldn't work 100% on car carbs rather than bike carbs.
As mentioned above, I woulnd't like to put a non bike pump onto carbs as they will most likely over pressure or be regulated so low they'll
underfeed the carbs.
The bike pump has cut out a couple of times , twice due to blocking up, sorted that, and once for no apparent reason, i think it might be because
it's strapped directly to the chassis, it's been reconnected now and seem's to work, i just need a way of fixing it vibration free.
TextWhen the bike pump cuts out, does the car cut out too?
Hi Brad don,t be tight get a new one
could it be a faulty electric plug - fuse holder - is it definatly the pump
Graham
[Edited on 24/1/07 by jacko]
definately the pump.
Cheers Graham.
If you pipe both pumps in series then the lesser pump will be irelevant as the higher capacity/pressure pump will take over.
It would mean that if one failed the other would still be there as backup and it would cause no ill effects running both.
I just ran the mechanical pump with my R1 carbs n the Pinto. No problems in 5000 miles.
Originally posted by stevebubs
Unless the combined pressure is enough to overcome the regulator....then you'll end up with your float chambers being overpressured...
My mate had the same prob it would just cut out when it felt like it we got another pump and has been fine.
