Zetec fuel pipes
Ian D - 14/2/07 at 07:54 PM
Guys,
Still more problems. How are the standard Ford fuel pipes connected to the Zetec inlet manifild as they dont have a fuel type jubilee clip fitted. I took mine off planning to use some new flexible fuel hose. However I cant clamp it with a fuel type jubilee clip and now the Ford pipes are loose so wont be fuel tight.
I have a siver top Escort engine with the inlet manifold that goes over the top.
Ian
zzr1100rick2 - 14/2/07 at 08:10 PM
mine had quick release connectors that pushed on to the fuel lines on the manifold sounds like you need a trip to the scrappys
snippy - 14/2/07 at 09:10 PM
Ian,
if its the quick release connectors (one red, one white?) your are in luck. I currently have an engineless Mondeo 2.0 Zetec on my drive. I can cut some lengths of fuel pipe off with these connectors on the end if it helps? You will then just need to attach a piece of pipe and jubilee clip to the other end.
Nick
Schrodinger - 20/2/07 at 01:23 PM
IIRC they are 10mm od and you can get ordinary compression plumbing fittings to work on the ford pipe.
