I need some help with my map.
The engine is a 2 litre blacktop with GSXR 600 throttlebodies and injectors with EDIS.
Can somebody cast an eye over my settings please as there is something.
What problmes are you having?
mainly seems to be overfuelling, but i mean to the extent of flooding the cylinders
I tried looking at it for you but gave up. If I try to download it it comes up as an XML file. If I copy the text and save as an MSq then it has
garbage values in fuel req etc.
If you attach a downloadable file I will have a look. A datalog would also be sensible if you want answers to what is going wrong!!
managed to get it running of sorts, i found a problem the injectors seem to keep going into test mode, no matter how many times i set it in normal mode and burn to ecu. I will get my adjusted map and datalog on later when i remember to turn the datalogging on
try before posting zipping or rarring the file it will help fooling the file/download/browse system
Tks
