Evening all,
Well, the collecting of components for the injection / megasquirt setup is going OK, but I need a fuel pressure regulator. Looking on the Bay, there
are loads of these: clicky
They do look a bit chavvy, but will they work, and (probably more important), pass the SVA?
TIA,
Vince
You'll just have to mount it in a prominent position or paint it over with black hammerite - Reasonably cheap for the spec...
Vinney,
Get one with a presure gauge as this is very usefull for fault finding set/up.
On mine the vacume side is disconnected as the EFI can do a better job of controlling how much fuel to lob in.
personally using an FSE regulator.
regards
Agriv8
get a fse the cheap ones are a pain in the arse to set they have cheap plastic diaframs in.
adam
I'd definately get one with a pressure gauge in it- especially on a cheap one. At least you can monitor the pressure so you know when it goes pete tong....
I've got an FSE with gauge - very handy when mapping.
If you are running separate throttle bodies this is understandable. However if you have a plenum and a single (or two) throttle bodies and are using a MAP sensor for load sensing then I don't agree. The baseline fueling level on ECU's like the Megasquirt and VEMS assumes a constant fuel pressure for starters.
If ECU's were better than a relative pressure regulator, why would any car manufacturers ever bother with them?
I've always had trouble understanding the need for a vacuum triggered regulator. As Agriv8 says, it would more logical if the ecu was to take complete control but I seem to recall that injector duty cycles are a limiting factor here, and the resolution is easier to calibrate when you can increase the pressure at appropriate times. I am not sure of the reasons behind this though - maybe you can fool the ecu into thinking you have bigger injectors but still keep the engine frugal at lower revs?
I think you will find the reason manufacturers use a vacuum operated regulator is down to price £££ ?
Why would fitting another or more complicated part be cheaper if it can all be done in the ECU?
By reducing the rail pressure at low load (high vacuum) you need to open the injector for longer to get the same amount of fuel. This means that you
can make small adjustments to the amount of fuel easier at such loads because there is a limit on the resolution of the ecu to be able to control the
pulse width.
Originally posted by chriscook
By reducing the rail pressure at low load (high vacuum) you need to open the injector for longer to get the same amount of fuel. This means that you can make small adjustments to the amount of fuel easier at such loads because there is a limit on the resolution of the ecu to be able to control the pulse width.
