Hi!,
I am going to fit an in tank fuel system to my Luego. I plan to use a Subaru Impreza in tank pmpand sender unit. To do this I need a tank with a
sump to get the height. Can anyon recommend a source to get the tank made also do I need a vent in the tank. I am fitting an st170 using jenvey
throttle bodies and std injectors.
thanks
Dave B
Morning Dave
Not sure about where to get the tank made but in any case you will definitely need a breather to stop pressure/vacuum building up.
