I need to route a fuel breather pipe in a tight 180 degree bend and can't find anything that doesn't kink easily. I have tried bending some
6mm alloy tube around a 25mm pipe but it kinks every time.
Is there anything like a U bend with a 6-7mm o/d?
this kind of thing?
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=281_430_286_301&products_id=1776
Erm .... a bit ott at £14 each
I was thinking a bit more locost than that - basi8cally a bit of bent 6mm pipe
Can you fill the 6mm ali tube with sand before you bend it?
yeah, £14 is a bit much, but its there if you're stuck
or maybe this one!
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=281_430_286_301&products_id=1779
this ones £11.84
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=281_430_286_301&products_id=1775
[Edited on 21/10/07 by blakep82]
Put a piece of wire inside the pipe then bend it. Pull the wire out or melt the insulation off if it's too tight and pull it out a strand at a time
Does it have to be 6mm?? I'm thinking 2 of 90 degree 8mm elbows for microbore heating pipes.
OK another thought what about a bit of pipe from the condenser on the back of an old fridge or freezer??? Just be carefull of the refrigerant when removing it
6mm for fuel breather -- way over the top even a bit of 3/16" brake pipe is big enough for a breather.
