I need to get some adaptors made up to attach to my existing inlet manifold. They are very simple in design, just an attachment the same shape as a
weber, with a small piece of 40mm tube attached - would prefere to make from stainless - can anyone suggest a company to do this....Thanks.
PJ.
If you do a bit of searching on here there is someone who has had some of these made up already...
Thanks all for the inputs - I just bought some adaptors from ebay for £15
Inlet manifold adaptors for throttle bodies or carbs x 4
No idea what they will be like as there was no pic, but wortha pumt for £15 - Will not go to throttlebodies.com for obvious reasons!!!!!.....
The jenvey fuel rail does not fit the GSXR600 injectors (as far as I can tell) - but I have got an extruded blank that needs drilling -
Thanks again.
Paul./
Thanks again.
Paul./
