I am trying to find out if I can use a one peice unit inside an MK tank which incorporates the pump, sender and swirl pot. If this can be done, anyone
know of a unit. The tank depth is 255mm.
Secondly - what pressure does the injection system work on eg what pressure does it need regulating to?
Thank you in advance
JK
On my old 929 blade I used the orignal bike pump,mounted in the bottom of the mk tank,they run at aound 45psi,I find its always best to use original equipment if and where you can,the pump also has the the low fuel warning light built in,so this also saves on fitting a fuel sender,cheers Paul
I take it there is no concerns with being low to the floor?
Did you fit a cover around it for protection?
As above - Use original pump wherever possible, and yes it will easily fit into your tank.
here you go (but there are others on there!):
EBAY LINK
The fireblade pump is regulated at 43.5 psi
Anyone got any photos of the pump fitted in the tank??
Thanks in advance JK
