Hi All,
Just finished building my megasquirt, its a V3 board MS1 setup for wasted spark ignition. I've got megastim, but can't really find any
instruction on testing the MS to ensure it is fully functional. My original plan was to install it over the winter, but as winter is nearing an end
(hopefully) I really don't want to start pulling the car apart to put the MS on and find it aint working, and then waste the whole summer trying
to fix it.
So anyway, if anyone can give me some instructions on testing the MS off the car I would be very grateful
Scott
PS When I got my MS from DIY Autotune I got one of there pre wired connector, but it aint fully wired for the MS-Extra, does anyone know where I
could get the pins to add some wires to this.
[Edited on 29/1/08 by phoenix70]
Hi.
you need an stimulator card.
It plugs into the MS and has dials etc on it so you can simulate a running engine.
Do a search on google.
[Edited on 29/1/08 by piddy]
If you have the simulator then you just connect it to the ecu and connect the ECU to the pc with the tuning program running.
You can then see the dials on the screen change when you adjust temp, revs, O2 ,and throttle position on the simulator.
It will give you and idea of how it all works but until it is installed you can only check the basics on the sim.The ecu will have a basic map in it
but you will need to install a correct map for your engine.
Paul.
I've got a stim and I've plugged it all in to, but I kinda expected to get some more feedback from the LED on the MS and the stim, but they
don't seem to do much.
Cheer
Scott
Don't forget to turn 'Wheel for stim' on in Megatune or else it will just sit there.
Once it is on then you should get flashing injection leds and fuel pump led.
It MUST be turned off again before you put it in car.
Can you tell me where the wheel for stim setting is?
Under the 'spark' menu as 'Stim for wheel'
Once turned on you should get dancing injection leds.
