Hi All,
I've driven a few different cars with different fuel injection systems. For some of them (newest types), the throttle response was disgusting:
-sluggish and lots of lag;
-you could actually feel electronic closed loops acting when doing some things like parking etc;
-if driving any hard, very difficult to avoid rpms increase briefly when pushing the clutch in order to shift up due to lag (only way was to release
throttle totally, wait, push clutch pedal).
I just hate all that and I would like to learn from you guys what system brought that to cars because I'm useless with mechanics. I was
suspecting this would be inherent to the EFI systems. But recently I found that the MX-5 mk1 (which has a nice throttle response in my opinion) had
EFI:
The engine employs an electronic fuel injection system using a vane-type air flow meter and a camshaft angle sensor instead of a distributor.
http://en.wikipedia.org/wiki/Mazda_MX-5
So now I don't know what to blame for the terrible throttle response that some cars have. I thought it would be the EFI in itself and I would
have to live with carbbed cars forever because of this (I love them but they are not great for the environment).
Comments, experiences?
Alex
It's all emmisions bollox, throttle must open and close smoothly, fuel cut at any excuse etc.
I'm sure that if you could map a modern car yourself most problams would go away
I found many modern cars to be very sluggish reducing revs, especially when changing gear or even the revs increase when the clutch pedal is pressed
even though I have lifted off the throttle. Usually results in me smashing gears and swearing a lot, very annoying.
Grounds for getting rid of a car very quickly.
Originally posted by Alez
So now I don't know what to blame for the terrible throttle response that some cars have. I thought it would be the EFI in itself and I would have to live with carbbed cars forever because of this (I love them but they are not great for the environment).
Cheers, it all makes perfect sense now because the MX-5 is a '91 therefore emissions and fuel economy are not as restrictive. Also the cars
I'm hating the most because of this effect are all very new (my brother's Golf mk4 is one example).
Thanks!
[Edited on 22/4/08 by Alez]
Originally posted by MikeRJI recently drove a new shaped Astra 1.6 SXi, and the performance (or rather lack of) was simply laughable, my old 1.1 Fiesta was quicker off the mark.
I had the misfortune of hiring a 1.8 auto astra a few months ago, as you drew to a halt the gearbox disengaged and you jolted to a stop, when pulling
away it span up then you felt the clutch bite and off you jerked..... all very poor.
Unfortunately it has to be said, get a proper jag none of that fluffy rubbish as tehy are meant to go fast!
