Will wire LC1 Innovative lamber sensor to MegaSquirt later.
Quick look last night, do i connect the Brown or White LC-1 lead to Pin 23 on the MegaSquirt? Or both white and brown?
erm, either, I think. If you have 6 wires should be following:-
a. Red 12V supply
b. Blue Heater Ground
c. White System Ground
d. Yellow Analog out 1 ( to pin 23)
e. Brown Analog out 2 (or this one to pin 23)
f. Black Calibration wire
or if you have 7
a. Red 12V supply
d. Yellow Analog out 1 (to pin 23)
e. Brown Analog out 2 (or to pin 23)
f. Green Analog Ground
g. Black Calibration wire
Outputs can be configured in the software.
[Edited on 29/7/08 by darrens]
