Open source android dashboard
Pdlewis - 7/3/13 at 09:05 AM
Morning,
With the huge reduction in the price of 7" tablets i have been wondering about creating a second dashboard with one. I wondered if anyone knew of any existing projects out there before I look at doing a scratch build because there is a lot of work to build an interface for the sender signals and the software side of it
40inches - 7/3/13 at 09:53 AM
Some discussion here. Most I have seen use the CanBus/OBD2 for the interface, not what you need I think?
Slimy38 - 7/3/13 at 09:58 AM
If you want to hook up to senders etc, I would probably suggest getting an Arduino dev board and the Amarino Android kit.
designer - 7/3/13 at 10:15 AM
I've seen this done on a home built plane in California. It had a two switchable displays, one for the engine/flight monitoring and a second for navigation.
It was a good piece of kit but, when I asked how it worked it all came across as gobble-de-guke. It's probably simple, but beyond me.
ashg - 7/3/13 at 10:26 AM
If you have a megasquirt ecu it already exists in several flavours
Pdlewis - 7/3/13 at 10:35 AM
unfortunately Im using the stock r1 engine management.
When i first thought of it i looked at the Amarino Android kit looks very nice and might be the best way to go. I have left this to the wrong time of year, I should really have looked at it when the nights were dark and cold
scudderfish - 7/3/13 at 10:43 AM
This may cut down on the interfacing work for you
https://www.sparkfun.com/products/10748?
Steer clear of any thought of using Bluetooth, go for a USB based interface as it has much better latency characteristics and throughput.
matt_gsxr - 7/3/13 at 11:13 AM
If you do this with Arduino then go for the mega board because it has more inputs (hence more flexibility).
I'd worry a bit about how to deal with rev counter and speedo (fast triggers) owing to the way that the programming works (it is all sequential stuff). I had a speedo working fine, but not sure what would happen if a speedo trigger coincided with a tacho pulse.
The ADC's on Arduino are not that fast either.
But cheap and easy to play with.
Slimy38 - 7/3/13 at 11:52 AM
Those ADC's are plenty fast enough, they can deal with kilohertz sampling rates. I've seen them working with video capture (albeit fairly blocky black and white images).
scudderfish - 7/3/13 at 01:30 PM
The display will have some damping applied to it, otherwise it would change too fast to read. If done correctly it should be tolerant of a missed read or two.
Think of it this way, MSDroid, TunerStudio etc do a good simulation of a dashboard with an update rate no better than 25Hz. If your primary consumer is a pair of eyes (rather than a log file), this is fine even if you've potentially missed hundreds of potential reads in between.
