Hi Guys,
Took my Fury out today for a shaake down run to test the brakes gears etc and although it was quite a bumpy road I was finding I was bottoming out
quite alot to the point where I have given my sump a bit of a grounding out.
What sort of ride height are you guys running. I have the ProTech shocks and the collar is wound quite far down so I guess I need to run this up a bit
to give me the extra ground clearance.
Also when on full lock the right front tyre is rubbing on the headlamp housing bodywork part, will this also clear once I have raised the ride height
do you think?
I'm not sure if it's any help but I've got a stylus so similar chassis to the Fury but with a live rear axle ( mk2 escort )
The front lower corner chassis rail is 125mm off the ground, 11" protech dampers revalved by procomp, 250lb springs, rear are 220lb springs
again protech dampers revalved by procomp
Shooter
Hi Martin,
Just checked and I have 120mm at the front lower corner.
Initially I had my dampers at the softest setting.
When my corner weights and suspension were set up, they were adjusted 5 clicks. (Spax units)
Hope this helps.
[Edited on 3/6/17 by avagolen]
The front lower corner chassis rail is 125mm off the ground, 11" protech dampers revalved by procomp, 250lb springs, rear are 220lb springs again protech dampers revalved by procomp
Shooter
Hi Martin,
everything good?
I just wanted to know how it goes with your fury.
Now it's been a while for you to complete it.
Are you satisfied with the car?
and the engine?
and very challenging to drive?
and very rigid on the road?
mine was like yours and ground away the back of the headlight bowl. I modified them slightly and wound the suspension up. The next step is to fit the LED lights and trim the back of the bowls then I can reset the ride height
Originally posted by Samuele
Hi Martin,
everything good?
and the engine?
very well Martin,
I am pleased to.
this gives me a good push to continue the work on my fury
very well Martin,
I am pleased to.
let's say something I did,
I'm not at this point in here I was hoping to be but all in all at least until now it seems that everything is good.
since Photobucket has made problems I did not know how to post more photos ....
do you have a good alternative to Photobucket?
perfect,
I did it.
Now I can post some new photos
