Where to buy rubber?
grazzledazzle - 23/8/10 at 11:14 AM
I need a roll of rubber 50mm wide (approx) 5mm thick (approx) and about 8 metres long. (can be in section of no less than 2 meters.
I want solid rubber to use as a packer, not the neoprene foam / rubber stuff advertised on ebay. Any ideas? I'm drawing a blank.
mistergrumpy - 23/8/10 at 11:18 AM
It sounds like the rubber earthing strips that we used to use on trailers in the RAF.
A search around those lines may help?
I'll have a look.
balidey - 23/8/10 at 11:21 AM
Depends where you are, but we use our local rubber supplier called Nene Rubber in Peterborough.
I am sure you have local companies offering similar.
mistergrumpy - 23/8/10 at 11:22 AM
What about this place?
Just looked again and it blatently says neoprene, sorry. I'm still sleepy, back on the night shift tonight!
[Edited on 23/8/10 by mistergrumpy]
mookaloid - 23/8/10 at 11:31 AM
old conveyor belting?
spdpug98 - 23/8/10 at 12:19 PM
Not sure where you are based, but there is this company in Southampton: http://www.portmererubber.co.uk/component/option,com_frontpage/Itemid,1/
UncleFista - 23/8/10 at 01:13 PM
www.bradfordrubber.co.uk ?
adithorp - 23/8/10 at 02:18 PM
Woolies do it by the metre.
50x1mm @ £1.67/m
50x1.5mm @ £1.47/m
50x3mm @£2.20/m
Item no88 page21 of the catalog
adrian
[Edited on 23/8/10 by adithorp]
grazzledazzle - 23/8/10 at 04:02 PM
cheers, all sorted
