I have an infestation of moles burrowing amok in my back garden. Short of hitting them with a spade whats the best thing to get rid of them?
Have heard of some kind of sonic device which is supposed to scare them away...these any good?
You can get garlic-infested balls which you bury and apparantly they don't like. Available from quite a few of the organic gardening shops.
Personally I don't mind too much about moles in my allotment. Anything which aerates the soils is only a good thing
Moles
Chris
sorry I'd just resort to WWI trench tactics and blow the b&ggers up with cherry bombs some might consider that a bit nasty though
do you have a dog?
It's worth paying some money to a molecatcher - very quickly. The little beggars breed very quickly, producing around 5 or 6 offspring every
time. The moles that is, not the catchers!
Our village playing field had moles, and the molecatcher got rid of them quite smartly.
There's only one way to get rid of a mole...... Blow it's bl**dy head orf!!
Alex.
The sonic jobbie will just drive them into your neighbours garden, unless they have one that has just driven them into yours of course!
You can't buy the poison that used to be available, but you can use the spring traps to kill them. If you use the spring traps boil them first
and then only touch them with gloves on. Moles are incredible sensitive to the smell of people. Dig up a tunnel - you can find where they are by
pushing a piece of 10mm bar into the ground and feeling for the 2 inch drop when you go into a tunnel. Make sure you backfill with the soil (gloves
still on) and no daylight can get in - a upside down dustbin over the top works well for this, and stops cats and dogs pestering the traps where the
handles stick out the ground.
Moles work on a cycle of 4 hours on 4 hours asleep. during the "on" hours they patrol the tunnels looking for worms that have dropped in, so
you should get a result in a few hours. Each mole will make 20 to 30 hill if left to it.
Best of luck
Hugh
I use the local molecatcher at £10 a visit. Apparantly yhere are still stochs available of the cyanide they use to kill them.
I had considered using butane gas in the tunnels and igniting it - the mind boggles at flying moles- but someone told me it would kill the grass!!!
Some interesting replies.
What's really annoying is if they move 12ft back from where there are digging they would be in a nice big field!!
Might give the sonic jobbie a go see if I can drive them into the field, failing that will probably use Mr WHippys idea with the cherry bombs
12 gauge shot gun?
Try Strychnine!
Or you can borrow our dog, she spends hours waiting for them, next thing you know....one dead mole in the middle of the lawn covered in dog slobber
(Apparently they taste so cr*p even the foxes won't touch 'em)
get a farmer with a licence to use phostoxin, it is a cyinide base posion, these pellets are very nasty, they react with moisture in the air and
release the gas, farmers and pest controlers use them to control rats, rabbits and moles. the typical cost is £1 a tablet and a call out fee. you
normally put a tablet in each new hill, these tablets do work very well. but remember moles are territoral and new ones will move into the burrows so
you might have to treat it more than once, ive got a licence but my call out fee to where you live would be huge.
hope that helps
Ed
