I am sure this has been done to death, but a breif search did not give me the answer, there was another What Oil thread but that was for bike
engines.
2.0L Pinto Running 45's Dellortors.
I have been recommended
10w-50
or
15w-50
What are you guys using?
D
Castrol magnatec for conventional engines
[Edited on 24/4/07 by Mr Whippy]
iron block vauxhall xe pretty sure I'm running oem spec 15/40 semi (Comma)
Ned.
Im using budget 15W40 at the mo. I think this is leading to some breathing issues. Im considering a swap to 20W50 at oil change time.
Research ive done suggests good quality mineral oil is best for Pinto's. Some recommend Valvoline but im not sure what grades it comes in.
Just been to look at what was put in last time and it is a semi 10w-40.
D
just changed to this oil,apparently the pinto hot rodders use it.Noticed the engine is quieter and pressures are up
