Lambda Sensor Wiring
the_big_1 - 1/4/21 at 05:17 PM
Hi Guys,
Just got to wiring up my Lambda a sensor and stuck on a couple of connections.
So 2 wires are heater, ground and ignition.
Other 2 are Sensor Signal And Earth.
But the Black top ECU has two pins of the ECU, pins 60 is called "HHO2S 1 signal " and 93 is called "HO2S 1 control"
Anyone know which is which?
the_big_1 - 1/4/21 at 05:38 PM
Hi guys,
Lots of searching seems to point to the following, can anyone confirm?
Original Pin 1 - Gn/Ye (Power hold relay) = Heater + (universal Sensor White wire)
Original Pin 2- Bk/Ye (Pin 93 HO2S 1 control) = Heater -(universal Sensor White wire)
Original Pin 3 - Bn (Sensor Common Spliced in to pin 91) = 02 Signal Ground (universal Sensor Gray wire)
Original Pin 4 - Wh (Pin 60 HO2S 1 signal ) = 02 Signal (universal Sensor Black wire)
big_wasa - 1/4/21 at 07:09 PM
There are two circuits. The heater and the sensor.
12v to the heater the ecu controls it by switching the earth.
The sensor has the sense wire and a common sensor earth.
the_big_1 - 1/4/21 at 07:12 PM
Hi ya,
Does my pin out look good?
The Universal sensors are not good at matching up etc?
