adrianreeve
| posted on 30/1/09 at 12:02 PM |
What do we think about these throttle bodies?
Hi there, followed Big Wasa's advice and bought some bodies off ebay for £35. Got excited, because the description was for CB900 throtle bodies,
but the piccy was GXSR600 TBs.
When they arrived, they are the CB900 Hornet ones. From a quick bit of research, the GSXR ones have 38mm bore, and the CB900 ones have 36mm bore.
My question is, are the CB900 ones going to be ok? I was thinking that Weber 40's ususally have a 34 / 36mm choke, so these should be at least
as good?
Could someone just put my mind at rest!!
Adrian
| posted on 30/1/09 at 12:09 PM |
Just depends what engine your running. I got some off the bay this week and measurign them they are a whopping
55mm
adrianreeve
| posted on 30/1/09 at 12:12 PM |
Sorry, being stupid! They are for a 2l Zetec Silvertop.
Adrian
MikeRJ
| posted on 30/1/09 at 12:29 PM |
They will flow better than a DCOE40 even with the maximum choke size fitted so I wouldn't worry about it.
grazzledazzle
| posted on 30/1/09 at 01:28 PM |
55mm
Are you aware you might have some real problems with these? Might be worth selling on and getting hold of something circa 42mm which is ideal.
mark chandler
| posted on 30/1/09 at 01:31 PM |
The bike would run around 150-160bhp with margin to improve on this, should be good to around 200bhp I would have thought.
Because they are a little smaller you will get a better MAP signal drivability improved in the mid range etc. How often are you at 7000rpm foot hard
down?
Also no secondary butterflies to rip out and can be spilt into two pairs.
"ideal" springs to mind.
stevebubs
| posted on 30/1/09 at 01:42 PM |
They sound fine for a standard engine.
cd.thomson
| posted on 30/1/09 at 02:12 PM |
55mm
Haha, yes he knows, theres no telling him though!
Craig
| posted on 30/1/09 at 03:10 PM |
55mm per body! Holy moly!! That's seriously big. That's the recommended throttle body size for 160Bhp for a SINGLE THROTTLE BODY!!!!!!!
| posted on 30/1/09 at 04:29 PM |
So, four of them mounted straight against the head... VROOOOOOMMMMM!!!!!
I do have a 43mm set as well as the 55mm ones are single and I need 4 then mounting them together etc...
adrianreeve
| posted on 30/1/09 at 04:59 PM |
Thanks for the replies chaps - looks like I have got myself a good set then!
grazzledazzle
| posted on 30/1/09 at 05:16 PM |
Or cough splutter stall...bastard won't start?
