omega0684
| posted on 7/2/09 at 02:52 PM |
quick MS question
just went to start my engine for the first time since putting it away for the winter and it won't tick over, it fires up turns over for a few
seconds and then cuts out. im pretty sure that the warm up enrichments are ok, but i can recall that this event means that there isn't enough
fuel getting to the engine (running too lean) can anyone confirm?
designer
| posted on 7/2/09 at 03:21 PM |
Are you using fresh petrol?
omega0684
| posted on 7/2/09 at 05:01 PM |
the tank was half full when i left it, so no, my intension was to run it once or twice a week but just haven't got around to it
mark chandler
| posted on 7/2/09 at 05:09 PM |
How long is a few seconds, is this always the same ?
MS will prime the fuel pump but needs to see the engine running to keep pumping fuel, does the LED flicker.
omega0684
| posted on 7/2/09 at 05:21 PM |
yeah the cranking is fine and the engine picks up the engine then ticks over at about 800rpm and then dies, runs for maybe 5-6 seconds. i think that
the ASE's might need increasing by 20-30% just to inject that little extra fuel.
mark chandler
| posted on 7/2/09 at 05:34 PM |
Okay before it should not have changed except that its very cold, have you set up the sensors correctly with ice and boling water using megatherm?
omega0684
| posted on 7/2/09 at 06:01 PM |
yep sensors are all set up correctly i got them straight from the chap i got my MS from and so they don't need changing using
megatherm/easytherm
martyn_16v
| posted on 7/2/09 at 06:09 PM |
Has it ever started when it's been quite this cold outside?
I'd whop up the ASE and the lowest warmup enrichments until it goes.
