geoffxt
| posted on 11/3/09 at 10:16 AM |
changing dcoe 40's to throttle bodies
I saw a thread in this section which contained photos of dcoe 40's which had been adapted/altered into throttle bodies. Does anyone have an
article or knowledge of how this is done please?
Geoffxt
wilkingj
| posted on 11/3/09 at 10:23 AM |
Some Jenvey bodies will fit DCOE 40 manifolds.
However Jenvey's are not cheap.
Think Bike throttle bodies, and Megasquirt.
Its a bit more work, but more in the locost Spirit.
Which ever way you go, its more expensive than carbs.
Best Regards
Geoff
http://www.v8viento.co.uk
cd.thomson
| posted on 11/3/09 at 10:38 AM |
do you literally mean stripping the guts out of a Weber, leaving only the butterfly and getting an injector mounted somewhere to give EFI using the
DCOEs as the throttle?
Craig
britishtrident
| posted on 11/3/09 at 11:05 AM |
I have seen it done --- you really don't want to go down that route, the webers are worth money sell them and either buy throttle bodies to
fif the manifold or use bike throttle bodies.
geoffxt
| posted on 11/3/09 at 11:43 AM |
Thanks for the very prompt responses. Craig has hit it in one. I do mean rip the guts out of Carbs and fit injectors! I might end up using bike
carbs but for the moment am wanting more info on the carb. ripping!
Mr Whippy
| posted on 11/3/09 at 12:46 PM |
Interesting idea, I suppose you could drill holes for the injector into the manifold or mount them at the top spraying into the inside of the
carbs?
[Edited on 11/3/09 by Mr Whippy]
maskedavenger
| posted on 11/3/09 at 05:48 PM |
WHAT ENGINE IS IT ON
geoffxt
| posted on 11/3/09 at 05:55 PM |
Pinto!
MikeR
| posted on 11/3/09 at 05:56 PM |
It was done in Car and Car Conversions years ago.
I keep being tempted with the idea - means you've got the look of webers without the hassle.
(i've already got the webers - but they'd need a rebuilt and jetting before i could use them)
geoffxt
| posted on 12/3/09 at 05:51 PM |
You're quite right Mike. I saw the CCC article and did'nt keep it. I am still trawling around and if I find anything to throw light on
this I will naturally post it on site.
