speedyxjs
| posted on 13/3/09 at 03:38 PM |
Fuel Delivery
Im still undecided as to what fuel delivery system to use.
A rough idea of cost of megasquirt would also be helpful.
Engine is 3.6 AJ6
Vote NOW!
flak monkey
| posted on 13/3/09 at 03:41 PM |
Megasquirt.
Will probably cost around £400 inc throttle bodies etc to fit. As long as you can make your own manifold of course.
Either that or it has to be triple webers
Sera
http://www.motosera.com
speedyxjs
| posted on 13/3/09 at 03:43 PM |
Yeah, i thought about that but £700 is a bit ott imo
owelly
| posted on 13/3/09 at 03:52 PM |
I have a bank of three carbotooters off an outboard engine. They're big!! Probably big enough to tandem two pots per carb or get another set of
matching carbs. No-one has cottened on to these carbs yet so grab them before they do!!!
http://www.ppcmag.co.uk
mark chandler
| posted on 13/3/09 at 04:59 PM |
Two lots of triumph trident TB's or cut some scabby carbs up and mount the butterfiles on the original manifold and use standard injectors. MS
away you go.
Daimo_45
| posted on 13/3/09 at 07:21 PM |
3.6 guzzler will need this
speedyxjs
| posted on 13/3/09 at 07:50 PM |
Well, thats already pretty conclusive. Thanks guys.
