rookie-rod
posted on 21/4/09 at 03:56 PM |
fuel tank
hi am putting a zetec into my mk3 escort stock rod. have a inline fuel pump and acumlator witch i am goin to gravity feed from a gallon tank (race
only 10 laps) queston is i need to put a fitting into the bottom of the tank to feed around a 1/2inch hose to pump. atm it has the feed from top of
tank as was done using suction when using cvh on carb. but now need a fitting to put in the bottem of tank
big_wasa
posted on 21/4/09 at 04:56 PM |
You could try an aero tank barb see Link
rookie-rod
posted on 21/4/09 at 05:31 PM |
thats the type of thing i want but need it to take half inch pipe
Litemoth
posted on 21/4/09 at 07:53 PM |
Can you get inside the tank?
Weld a 1/2" bsp boss on and use:
[Edited on 21/4/09 by Litemoth]
rookie-rod
posted on 4/5/09 at 03:10 PM |
i can get in tank if have to as can just cut the top off and weld back on. but im hoping the pump will have enugh to suck the fuel out from top off
tank . will find out soon as almost ready to fire the car up. just finished my wiring and water today. so just fueling now
