Breaker
posted on 31/5/09 at 10:24 AM |
Duratec throttle bodies
Perhaps this is a really stupid question, but I was wondering why the fuel injectors are placed on the throttle bodies instead of leaving them at the
original position, closer to the engine ? (f.e. 2.0 Duratec)
flak monkey
| posted on 31/5/09 at 11:13 AM |
Better air/fuel mixing probably, but newer injectors have much better spay patterns (new bosch ones have smaller holes instead of one)
I am using the standard head location on my install and blanking off the ones in the throttle bodies mainly because I think it will end up looking
neater if nothing else.
Sera
http://www.motosera.com
MikeRJ
| posted on 31/5/09 at 01:11 PM |
Injector location, as with most other engine design is a compromise. Injectors close to the valve tend to give better emissions performance.
Injectors further away tend to give better power; really high performance engines have the injectors mounted at the ends of the intake trumpets.
stevebubs
| posted on 31/5/09 at 03:32 PM |
Fit injectors in both positions. You can then switch between them depending on the map position, or reserve the outer set for when you fit the
super/turbo charger....
