r1_pete
| posted on 5/8/09 at 06:16 PM |
Air temperature sensor with ITB's where?
Using individual throttle bodies, with either trumpets or individual filters, where's the best place to put the air temperature sensor?
Cheers.
Pete.
omega0684
| posted on 5/8/09 at 06:29 PM |
ideally you want to put them into an airbox and the have the sensor mounted in the air intake pipe that leads from the fresh air to the air box
jonesier1
| posted on 5/8/09 at 06:56 PM |
mine is under the manifold cable tied to the chassis rail and its fine with gsxr t/b's
im in my own little world...its ok though they know me there
brianthemagical
| posted on 5/8/09 at 07:00 PM |
In front of the trumpets, or some where close, so it measures the temp of the air feeding the bodies, as patronising as that sounds.
Even if it sucks air from the engine bay, or an airbox, just some lateral thinking is all it takes.
[Edited on 5/8/09 by brianthemagical]
robocog
| posted on 5/8/09 at 07:10 PM |
...as above
But try and reduce heat soak by mounting in rubber tube, esp if using megasquirt
eg Its the air your measuring temp of, not the backplate
I temporarily mounted mine sticking out of the bodywork at first, but when parked up with that side in direct sunlight it would lie to the ecu,
causing lean runnings till air movement got it reading closer to the truth
Same will happen after a run/parkup restart if its mounted directly to an alloy backplate or a nice chunk of metal
....not a massive issue, but worth bearing in mind when choosing the mounting place and type ;-)
Mine is mounted between trumpets of cyl 2 and 3 and is bonded to a rubber hose for insulation and to extend the nose into the airstream
Regards
Rob
[Edited on 5/8/09 by robocog]
r1_pete
| posted on 5/8/09 at 07:33 PM |
Thanks guys, I was thinking of mounting it on a plastic bracket close by the intakes, just need to decide on trumpets or filters now, I think
it'll be trumpets for looks and sound.
MikeRJ
| posted on 5/8/09 at 07:49 PM |
quote: Originally posted by r1_pete
just need to decide on trumpets or filters now, I think it'll be trumpets for looks and sound.
Why not both? That's would certainly be the preferred option for performance and longevity.
robocog
| posted on 5/8/09 at 07:57 PM |
another vote for both...you know it makes sense :-)
Regards
Rob
r1_pete
| posted on 5/8/09 at 08:00 PM |
Yes thats another option worth thinking about.
Eee theres some choices with this fuel injection lark....
I hope bike carbs and boggs manifolds are still in vogue when I ditch them, for FI
[Edited on 5/8/09 by r1_pete]
DaveFJ
| posted on 6/8/09 at 09:24 AM |
I have a plastic sensor from a rav4 and that is mounter on a strip of ally with the 'nose' of the sensor pushing down through the one of
the foam filter socks over my gsxr throttle bodies
Dave
