speedyxjs
| posted on 30/9/09 at 03:10 PM |
Pressure release filler cap?
I was playing with the cooling system yesterday and got thinking, can you get a pressure release filler cap for the fuel tank like you do with the
coolant resevior?
This would save me needing to play with extra fuel lines
Staple balls
| posted on 30/9/09 at 03:15 PM |
Aren't most caps vented anyway?
adithorp
| posted on 30/9/09 at 03:20 PM |
Why would you want your fuel tank to be pressurised?
http://jpsc.org.uk/forum/
speedyxjs
| posted on 30/9/09 at 03:29 PM |
You dont. Thats why you need a way for the vapours to get out/air to get back in.
l0rd
| posted on 30/9/09 at 03:31 PM |
Isn't this why you have those one way valves?
blakep82
| posted on 30/9/09 at 03:51 PM |
yeah, but i see what he's saying, it would be nice if that was built into the cap, rather than having seperate tank connections, valves and
pipes
________________________
speedyxjs
| posted on 30/9/09 at 03:56 PM |
Just found this that says it is vented. Any good?
adithorp
| posted on 30/9/09 at 04:06 PM |
But you were comparing it to a radiator presure cap, that holds presure up to a set level (say 15psi) and then releases anything over that giving a
presurised system.
With a fuel tank you want a vented system, so you need either a vented cap (prone to leaking) or a breather system.
speedyxjs
| posted on 30/9/09 at 04:08 PM |
presurised system.
How could a vented cap leak?
adithorp
| posted on 30/9/09 at 06:34 PM |
Vented caps basically just have a small hole to let gas in/out; no valve.
Fill the tank close to the top on a hot day. Fuel comes out of the underground tank at 15'c and then warms up and expands and out it'll
come. Or just corner hard with a full tank and a filler thats not far above the tank and you'll find out why early Metro's were recalled
for new caps after the Police crashed a few (fuel leaked onto the o/s rear wheel). Whereas with a breather with 2 way valve it'll seal.
speedyxjs
| posted on 30/9/09 at 06:59 PM |
^^^ Thanks
