Staple balls
| posted on 21/11/09 at 01:28 PM |
Engine cutting out.
my engine appears to cut out when I touch the throttle, seems to be an issue with the TPS, as it runs fine if i unplug the TPS.
using omex 500
Ideas?
cheers
| posted on 21/11/09 at 01:32 PM |
Could even be something as simple as a worn-out TPS.... The wiper tracks get worn it the wiper is at one particular position for a long period of
time...
Staple balls
| posted on 21/11/09 at 02:25 PM |
I did wonder about that, the tps seems to work in a reasonably linear way, though one of the doodahs seems to start at 1.something k ohm, rather than
0
Edit apparently the forum doesn't like symbols, how annoying.
[Edited on 21/11/09 by Staple balls]
austin man
| posted on 21/11/09 at 03:43 PM |
Have you tried recalibrating it through the ECU the settinggs can changes if the tps has been moves. Worth a try before bying a new one
Staple balls
| posted on 21/11/09 at 03:45 PM |
Yep, tried that, set it up as per the manual and no change, TPS does appear to be working though, no dead spots in the ECU.
I'm thinking/hoping it's possibly a wiring oddity somewhere, but the battery died before I got chance to test stuff.
loggyboy
| posted on 21/11/09 at 04:29 PM |
Does it have an idle control valve or simiar?
Staple balls
| posted on 22/11/09 at 02:19 PM |
More playing, still idles fine, stalls when I hit the noisy pedal even if the TPS is unplugged.
Staple balls
| posted on 22/11/09 at 02:55 PM |
Hmm, Seems like it's getting starved of fuel, no idea why.
