Blackbird Rush
posted on 7/12/09 at 07:48 PM |
Fuel Pump Voltage?
I can't get my FP to run?
It has run but not for a few months, got voltage at the pump when the relay is triggered (but only 11.9V).
If the voltage is too low will the pump not run at all or just slower?
Its a sytec bosch injection pump. (was new when bought and has only run in the driveway a few times.
Ta for any help.
Ash
will121
posted on 7/12/09 at 08:03 PM |
has it just stuck, have you given it a tap?
speedyxjs
posted on 7/12/09 at 08:10 PM |
My pump was running with only 10.9 at the battery yesterday (albeit very slowly)
richardlee237
posted on 8/12/09 at 04:16 AM |
Chances are that it is the stuck pump which is pulling the voltage down.
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
Blackbird Rush
posted on 8/12/09 at 08:05 AM |
did give it a tap, maybe i'll give it a bigger tap then.....
scudderfish
posted on 8/12/09 at 10:37 AM |
And if that doesn't work, keep giving it bigger taps until it is definately knackered
Dusty
posted on 8/12/09 at 11:42 AM |
Injection pumps generaly don't run long if dry or fed crud.
Blackbird Rush
posted on 9/12/09 at 04:52 PM |
Well just had another play with the pump and it still wont work, even jumping it off the battery charger, so i think its a gonner.
Also gave it a few bigger taps but nothing...
the pump has a decent prefilter so it shouldn't have crud in it, also it ran fine a few months ago and there is fuel in the tank & lines,
i'll pull it apart and see if its anything obvious, but in the meantime i guess i'll have to get another one......
Thanks for the tips etc...
