Author: Subject: megajolt + smiths rev counter
cd.thomson
posted on 1/2/10 at 10:22 AM Reply With Quote
more questions!
is there any reason why my rev counter would be reading twice the real revs compared to my MJ on the lappy?
Craig
r1_pete
posted on 1/2/10 at 10:29 AM Reply With Quote
If its a smiths RVC tach, they do that, see HERE , John re-calibrated mine for the MGB.
I dont understand why they do it, on normal ignitions they get 1 pulse per ignition event, i.e. 2 per rev, an MJLJ creates 1 pulse per ignition event, same 2 per rev......
irvined
posted on 1/2/10 at 10:32 AM Reply With Quote
Is it just when connected to the megajolt or is it also when you connect it up to the EDIS module?
http://irvined.blogspot.com
cd.thomson
posted on 1/2/10 at 10:34 AM Reply With Quote
ive only tried it attached to the MJ as i thought the outputs were identical?
Craig
mcerd1
posted on 1/2/10 at 10:37 AM Reply With Quote
I think it depends on which type of gauge you've got - I know there were some issues with the older type ones...
here's the links to the smiths fitting instructions:
linky 'old' type
linky 'new' type
cd.thomson
posted on 1/2/10 at 10:42 AM Reply With Quote
ah, its a new type,
i had followed that website right up until the bottom section, thanks for pointing out my stupidity
Craig
