dunk3
posted on 10/3/10 at 03:45 PM |
Which fuel pump
Hi all, what would be the best fuel pump to use , i will be using it on a 2.0 zetec blacktop with injection using a griffin plenum chamber, hopefully
it will be about 160 bhp. cheers .
James
posted on 10/3/10 at 04:18 PM |
I would use one of these in-tank jobs with sender, swirl pot etc. all built into one as to me this high-flow to swirl pot, high pressure-low flow to
engine seems a bit ungainly!
They were mentioned in PPC a couple of months ago. Sure someone will know some details. If not, I'll find the mag!
James
- Muhammad Ali
big-vee-twin
posted on 10/3/10 at 05:32 PM |
I have installed a baffled tank with built in sump rather than having a seperate swirl pot with an external pump from ebay
link the tank was expensive compared to a standard one but when you compare costs of two pumps and swirl pots I reckon
its bit cheaper overall and better reliability not having two pumps
http://www.triangleltd.com
britishtrident
posted on 10/3/10 at 06:02 PM |
see ebay item 280383962970 for an external pump at a good price.
[/I]
bimbleuk
posted on 11/3/10 at 10:39 AM |
If I can find the part number I'll post it for the external one 'm using. Very common pump from 90s Audi's and Golfs. The first one
I used was 2nd hand and lasted over 5 years before failing. I bought a replacement for £38+VAT.
The first one was still working fine up to 270BHP on my car.
