jimmyjoebob
| posted on 15/6/10 at 08:16 PM |
Rover v8 engine loom
I am currently installing a flapper afm type engine loom into my car - I didn't take the loom out of the donor. Is the engine loom separate to
or incorporated into the main loom? I have two 'red with yellow trace' wires appearing from the loom binding midway between the engine and
the ecu connection. All the diagrams I can find show no engine component using these colour wires (although it shows elsewhere in the car as fog light
wiring). Can I ignore them or am I using the wrong wiring diagram?
[Edited on 15/6/10 by jimmyjoebob]
If at first you don't succeed, hide all evidence you ever tried!
mark chandler
| posted on 15/6/10 at 08:22 PM |
Completely separate, from distant memory you have the plug midway, this needs a permanent battery, switched battery and earth. The two other wires are
not used.
jimmyjoebob
| posted on 16/6/10 at 10:34 PM |
Cheers for that - I unwound some of the covering from the loom around the mystery wires and it looks like they were added for an immobiliser/alarm
installation.
I have the wires you mentioned identified now so hopefully it will be running tomorrow evening!
