adrianreeve
| posted on 19/3/11 at 03:20 PM |
How and where to plumb in fuel pressure regulator?
Hi there,
The Jenveys and manifold I have bought don't have a take-off for vacuum for the fuel pressure regulator. Do I just need to drill and tap the
manifold, and if so, where is best? Or can I get away without connecting vacuum port, and just have a constant fuel pressure?
Adrian
will121
| posted on 19/3/11 at 03:31 PM |
Vacuum connection to fuel regulator just reduces pressure at tick over for better injection control but can't see it being an issue to map with
constant pressure unless injector are bit to big
| posted on 19/3/11 at 04:41 PM |
Didn't bother with a vacuum connection on mine , as said mapping should sort it out
adrianreeve
| posted on 19/3/11 at 04:48 PM |
Cheers guys
Bare
Sure.. but doesn't effective mapping require significant time an a 'decent' dyno, the fitting of a wideband lambda and an egt
device.
Seems to me to be way easier to say than do.
adrianreeve
| posted on 19/3/11 at 04:51 PM |
It's going to be mapped anyway, so no problem
