<<  1    2  >>
Author: Subject: Almost ready to give in
omega 24 v6
posted on 15/7/11 at 09:36 PM Reply With Quote
Firstly a big thanks to Phil for his help.
It looks like the problem was of my own doing. I took the covering off of my loom to find that in the dim and distant past I had actually grounded the vr -ve to the ecu ground ( externally) this coupled with the incorrect vr polarity was causing the problem. Swapping the vr wiring at the ecu ( which is what I did and thought would cure it) did actually give it the correct polarity BUT because it was grounded externally ( and I changed the wires internally) it now meant the vr+ was now grounded ( if you see what i mean).
I still have the induction clacking noise ( going to fit a filter box and filter a some point) but the timing is now advancing as it should and no acceleration flat spots at all. Great.
Again thanks Phil and everyone else for their help.
daviep
posted on 15/7/11 at 09:59 PM Reply With Quote
Happy days
Glad you got it sorted.
“A truly great library contains something in it to offend everyone.”
<<  1    2  >>
