Author: Subject: Copper fuel pipe
neilp1
posted on 4/9/11 at 04:48 PM Reply With Quote
Copper fuel pipe
Where's the best place to buy 8mm copper fuel pipe. This is for fuel injection. I intend to run 8mm rubber or braided pipe from the fuel pump to the copper that will run through the tunnel then back to rubber.
Will 8mm OD be okay for this?
Neil
britishtrident
posted on 4/9/11 at 05:37 PM Reply With Quote
LPG kit sellers sell rubber coated 8 mm or 6mmcopper fuel pipe in 6 metre lengths.
Auto Gas LPG
[Edited on 4/9/11 by britishtrident]
[/I]
MikeR
posted on 4/9/11 at 06:40 PM Reply With Quote
Find your local builders merchant / plumbers merchant and buy it there - its called 8mm microbore pipe. You can then get the solder fittings to do tight 90 degree bends if needed (although gentle bends are better for flow).
posted on 4/9/11 at 06:43 PM Reply With Quote
Kunifer is available in 8mm , available from your local motor factors, is less likely to kink than microbore and is stronger . The down side it is more expensive
neilp1
posted on 21/9/11 at 05:56 PM Reply With Quote
Can you buy this off the net if so where as I've done a search but can't find any. I've also contacted a couple of places local to me and they don't do it!!!
gavin174
posted on 21/9/11 at 06:13 PM Reply With Quote
8MM x 2.5MTR CUPRO NICKEL (KUNIFER) FUEL PIPE | eBay
also available in 7.5m lengths..
8MM X 7.5MTR CUPRO NICKEL (KUNIFER) FUEL PIPE | eBay
blakep82
posted on 21/9/11 at 06:21 PM Reply With Quote
got mine for the kip marina chandelry shop. i don't know if theres a difference, but they sell it as fuel pipe (not microbore heating pipe)
£2.60 per metre mine was. well happy with that. is there anything like that near newcastle?
________________________
