matnrach
| posted on 29/4/12 at 03:50 PM |
Modifying code
Hi all,
I have been using MS1 V3 with HiRes10g code for a while now with no problems
I am modifying my engine and need output 2 to switch a valve dependent on engine speed and MAP rather than just engine speed.
Is this difficult to do? Could anybody point me in the right direction
Many thnaks
matt_gsxr
| posted on 30/4/12 at 10:48 PM |
MS1 code is written in some kind of assembler. You can probably work it out if you've done a fair amount of programming, but it isn't
easy. I think the compiler and source are easily downloaded and installed.
Here are some clues:
http://www.megamanual.com/Tutorial.htm
MS2 code is written in C, that includes comments and help and such. It is much much easier and I managed to do a few little bits with it relatively
straightforwardly. Not much documentation though.
Matt
