Author: Subject: innovate lc-1 sensor position
dave r
posted on 22/4/19 at 02:33 PM Reply With Quote
Got a bit of a problem....
The boss in my exhaust is only 5/8 " tall
Innovate recommend 1"
So the tip of the probe will be properly in the gas flow rather than on the edge
Am likely to kill my new probe?
Bit of a pita to remove and put a new boss on
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
mark chandler
posted on 22/4/19 at 06:12 PM Reply With Quote
I have burnt up a couple of sensors due to this, can you not pop a thick washer on it?.
I ended up making an extension which cured things with the sensor up close to the manifold, if it's 24" away from the head it may be okay.
[Edited on 22/4/19 by mark chandler]
dave r
posted on 22/4/19 at 07:43 PM Reply With Quote
Will run out of sensor thread before I get it where it should be.....
CosKev3
posted on 22/4/19 at 10:43 PM Reply With Quote
Get an adapter made that screws into current bung,then sensor screws into that?
coyoteboy
posted on 22/4/19 at 10:50 PM Reply With Quote
My sensor boss is about 1/2 thick. Not burned up any sensors in 20K miles, 1 ft from the turbo.
Angel Acevedo
posted on 22/4/19 at 11:23 PM Reply With Quote
There are Spark Plug "Extensions" that use the same threads.
Also there are dedicated O2 Sensor extenders.
dave r
posted on 23/4/19 at 05:42 AM Reply With Quote
Does it matter if the sensor end is maybe 1/2" outside the exhaust diameter? I can make an adaptor
Guess it will slow response a bit?
furryeggs
posted on 23/4/19 at 08:56 PM Reply With Quote
I’ll check in the morning, I think i have an unused weld on boss from innovate...
dave r
posted on 24/4/19 at 05:58 AM Reply With Quote
I have the proper boss, just the wrong one on the exhaust
Welder is bust at the moment, and don't want to take the manifold off
