Author: Subject: Swirl Pot Return
ttalps2000
posted on 4/3/20 at 08:26 AM Reply With Quote
Swirl Pot Return
In the process of plumbing in my swirl pot. I am running a returnless system, so all i have coming into the swirl pot is the low pressure pump feed. I am struggling to find a position to put the overflow from the swirl pot back into the tank. However, i am running a Facet cube style pump for the low pressure feed. These pumps are designed for running with carbs, which have a float chamber and shut off the fuel flow when this is full.
So, question is, do i actually need a overflow from the swirl pot back to the tank? I see no issues with just blanking this off and letting the low pressure pump fill the pot up. Only issue could be a air pocket at the top of the swirl pot i guess?
If not, any easy ideas on getting a return connection into the tank? I was going to put it into the fuel sender, however it is too small to do so, so that option is out!
40inches
posted on 4/3/20 at 09:33 AM Reply With Quote
I ran the return back to the tank breather outlet and made another breather.
As you said the return is to bleed off any air, brake line is big enough, I have a 0.8 mig nozzle in the rubber tube from the swirl pot return.
voucht
Contributor
Posts 240
Registered 22/5/11
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 4/3/20 at 10:44 AM Reply With Quote
Hi,
I would install a return hose anyway, even with a self-interrupting Facet LP fuel pump.
Here are some 3D schematics swirl pot installations I did a few years back when I was working for a company involved in hydraulic circuits for racing cars. The difference between the 2 schematics is if you have a 2 or a 3 ways fuel pressure regulator.
Red cylinder = fuel filter
silver cylinder = high pressure fuel pump
golden cube = low pressure fuel pump
golden dome = fuel pressure regulator.
And I think it is pretty obvious where the swirl pot, the fuel tank and the interjection ramp are on the systematics
Hope that will help
https://vouchtroadster.blogspot.com/
https://cafrazx550.blogspot.com/
ttalps2000
posted on 4/3/20 at 10:55 AM Reply With Quote
The issue im getting is that i dont really want to drop the tank out and start drilling holes in it to get a fitting put in etc!
voucht
Contributor
Posts 240
Registered 22/5/11
Member Is Offline
Photo Archive Go!
posted on 4/3/20 at 11:03 AM Reply With Quote
Now I'm not sure I understood your first post. Are you running an injection (high pressure) or carbs (low pressure)?
ttalps2000
posted on 4/3/20 at 11:29 AM Reply With Quote
Injection, high pressure
indykid
posted on 4/3/20 at 11:38 AM Reply With Quote
One of these? https://www.parts4aircraft.com/fuel-tank-fitting-c2x9383165
Drill a hole, poke it in. No welding required.
There has to be a reason I've been saving this link all this time...
SPYDER
posted on 4/3/20 at 12:00 PM Reply With Quote
If you run too large a return from the swirl pot the low pressure pump will run at 100% all the time.
I have plumbed in a similar system to yours on my car. I have a pressure regulator after the LP pump set at around 1 or 2 psi which gives the LP pump something to work against. I also put a restrictor in the tank return line. I ended up at around 1mm IIRC. The LP pump still never actually stops clicking but it is running a lot slower. The possible downside of this is that the swirl pot is slightly pressurised but this hasn't caused any problems for me.
dhutch
posted on 4/3/20 at 02:53 PM Reply With Quote
Is this a problem? (genuinely dont know)
SPYDER
posted on 4/3/20 at 05:33 PM Reply With Quote
I don't know if it would be a problem with your pump either. I know that mine made a right racket if left running at full chat.
posted on 4/3/20 at 05:35 PM Reply With Quote
40 Inches has already suggested a solution in his reply
SPYDER
posted on 4/3/20 at 08:02 PM Reply With Quote
...and I agree with him.
ttalps2000
posted on 13/3/20 at 10:53 AM Reply With Quote
used one of these in the end: https://www.parts4aircraft.com/fuel-tank-fitting-c2x9383165
Seems to work well and installed within 10 mins! Just hope it doesnt leak now!
Also added a 0.8mm mig tip to add some back pressure etc
Mr Whippy
posted on 13/3/20 at 12:05 PM Reply With Quote
What about swarf from drilling the hole?
ttalps2000
posted on 13/3/20 at 12:09 PM Reply With Quote
coated the drill in grease and caught the majority of it all. Pump and tank has filters to catch any small bits
40inches
posted on 13/3/20 at 12:14 PM Reply With Quote
That's what I did, using a step drill. I used the Aircraft fitting for the breather and used the welded in breather for the return.
Both are on top of the tank so not submerged in fuel.
[Edited on 13-3-20 by 40inches]
