SteveWalker
posted on 27/5/22 at 11:27 PM |
Sierra 8 valve pinto fuel rail connection
I am in the process of preparing to replace my Weber 38 DGMS and hall-effect distributor system with Microsquirt, running ignition and
fuel-injection.
I have cut the flange from a standard EFI manifold, Lumiwelded tubes in to replace the runners and added individual throttle bodies from a
motorbike.
I am using a standard Sierra fuel rail to feed the normal injectors, inserted into the flange, but have lost the fuel feed connection to it. To save
me measuring and looking through both matric and imperial options, does anyone know what connection is used on it?
Grimsdale
posted on 1/6/22 at 08:56 AM |
the stock fitting is 6mm, but i recently found and fitted this to suit my 8mm rubber lines.
https://www.ebay.co.uk/itm/322519870385
SteveWalker
posted on 1/6/22 at 12:18 PM |
It's the size of the thread that I am interested in, rather than the hose barb. Is the thread on that nut the correct one? I didn't make my
question clear and unfortunately your reply is slightly ambiguous too.
