Author: Subject: OK - Lets get this forum started...
DaveFJ
posted on 1/12/05 at 11:33 AM Reply With Quote
I have a 2ltr EFi pinto and I am considering cutting down the EFI to fit under the bonnet instead of using carbs.
I have the instructions from the Luego build manual.
Anyone see any real problems with this ?
What do you think I should do about the ECU ? use the sierra one or go for a megasquirt ?
I'm a little way off yet but am interested in (and value) your opinions....
Dave
Gav
posted on 1/12/05 at 11:38 AM Reply With Quote
personally id go for megasquirt as this (imo )would give you a better understanding how it it all works, plus im a techo junkie
rayward
posted on 1/12/05 at 11:45 AM Reply With Quote
do you mean your going to cut down the plenum?
if so there is a minimum capacity it will need to be to suit your engine.
Ray
DaveFJ
posted on 1/12/05 at 11:50 AM Reply With Quote
not the plenum itself but Luego suggest cutting a 'wedge' out of the pipes to lower the plenum.
linky
Dave
posted on 1/12/05 at 12:00 PM Reply With Quote
That looks like a bit of a kink in the end two intakes.
DaveFJ
posted on 1/12/05 at 12:06 PM Reply With Quote
yep - was worried about that - thought maybe a length of tube on 3 and 4 would be needed to fix that ? might be difficult to do though.
the other alternative would be to make my own plenum but not totally sure I'm up to that ...
Dave
stevebubs
posted on 1/12/05 at 12:39 PM Reply With Quote
Megasquirt will probably be the cheapest, but it's largely a community-based thing. (BIG community, though)
If you're after a commercial offerning, Emerald are probably not that far away from you and the cheaper K2 ECU is due out early next year
piddy
posted on 1/12/05 at 12:55 PM Reply With Quote
If your looking to do it cheaply stick with the Ford ECU.
If you have money available then go for the Mega Squirt (well known and surported) or others like Emerald as suggested.take a look at this
Or here
[Edited on 1/12/05 by piddy]
timf
posted on 1/12/05 at 02:00 PM Reply With Quote
or use Mark Allanson's document
jon_boy
posted on 1/12/05 at 02:37 PM Reply With Quote
What a terrible peice of work the inlet manifold looks like. although im no expert it might be good. Is there no way of taking all the pipes off of the plenum and welding on new tubes just bent over 180 degrees?
romer
posted on 1/12/05 at 03:40 PM Reply With Quote
Does anyone know the e-mail address of Mark Allanson as the e-mail shown at the bottom of the above link doesn't work.
i.e. I assume he's changed his e-mail address.
Would love to know how he got on with this.
Romer
MikeRJ
posted on 8/12/05 at 03:39 PM Reply With Quote
I spoke to him at Exeter and he's very happy with it, no problems whatsoever.
