graememk
posted on 8/4/06 at 09:02 PM |
tell me about Injectors
how do they work, ie, do they have a permanent live and a trigger live and earthed vie the engine.
or am i wrong and barking up the wrong tree
is the trigger from the megasquirt + or -?
[Edited on 8/4/06 by graememk]
NigeEss
posted on 8/4/06 at 09:19 PM |
I always thought they were simply a solenoid with a +ve and -ve.
Unless it a Landy TD5 one which uses some sort of witchcraft
[Edited on 8/4/06 by NigeEss]
mark chandler
posted on 8/4/06 at 09:32 PM |
Not earthed via the engine, live feed and injection system pulses earth.
If you run them 100% then they burn out, the fluid going through cools them.
Regards Mark
zetec
posted on 8/4/06 at 09:34 PM |
My Emerald ECU has them wired with a common +ve ignition feed and triggers them with a -ve pulse the length of which determines the amount of fuel
delivered. Some require a resistor in series to work without burning out the ECU due to too high a current draw. I have Bosch/Vx ones fitted...£25 a
set s/h.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
graememk
posted on 8/4/06 at 09:41 PM |
got it straight in my head now thanks guys.
easy when its explained
