darrens
posted on 29/5/06 at 09:07 PM |
MS V3
Has taken me all day, but have managed to completely build my MS V3 board and tested OK , quite chuffed now, I had done a tiny bit on the PSU
before but has literally taken all day.
BTW I'm using a USB to serial adaptor and have had no probs.
[Edited on 29/5/06 by darrens]
stevebubs
posted on 29/5/06 at 10:01 PM |
Congrats...are you going to convert it to run the ignition in wasted spark mode and do away with the dizzy, too?
JohnN
posted on 29/5/06 at 10:26 PM |
How did you test it? have you also built a stimulator?
What was the make of the serial to USB connector - I have heard that many don't work?
darrens
posted on 30/5/06 at 08:10 PM |
I plan on doing away with the dizzy, but will be getting the engine started and running with the dizzy, then once I'm happy go over to spark
control. I have built the board with this in mind.
Don't know what make of USB adaptor (bought awhile ago off the net as I lost my original) it is but.....
I didn't build a stimulator, was fairly adventurous as I'd got most of the engine loom built I used that to test the operation of senders,
throttle position, fuel pump o/p, MAP is on the board itself so seen to be correct if the pressure reading is OK (and moves with vacuum and pressure).
Not test injector o/p yet though.
Regards
[Edited on 30/5/06 by darrens]
[Edited on 3/6/06 by darrens]
jambo
posted on 1/6/06 at 10:22 PM |
hi there, is making up the board require any electrical or soldering skills,do you need the know how?
stevebubs
posted on 3/6/06 at 01:17 PM |
Yes - built a stim.
I've 2 or 3 different makes ; they all work fine - just make sure you install the right drivers.
darrens
posted on 3/6/06 at 05:00 PM |
Some basic electrical knowledge, and a steady hand for the soldering
