Author: Subject: No Lambda sensor with MSnSE
Steve Lovelock
posted on 7/11/06 at 06:00 AM Reply With Quote
Hi, will be running MSnSE and wasn't planning to use a lambda sensor because I dont want the expense or hassle. Will this be ok?
takumi
posted on 7/11/06 at 08:16 AM Reply With Quote
MSnSE will work with no problem at all. I am going to be using MSnSE and a narrow band lambda.
At least with even a narrow band lambda sensor, you'll get an ideal if its running way too rich/or lean before black smoke or stalling gives it away..
New narrow band sensors are about £18 off ebay, surely worth the money when it comes to diagnosing mapping issues..
tak
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
Steve Lovelock
posted on 7/11/06 at 07:54 PM Reply With Quote
Put like that then £18 seems a fair price. What do I look for on ebay?
How are they fixed to the exhaust?
wilkingj
posted on 7/11/06 at 08:00 PM Reply With Quote
Look not to Ebay... but to the bottom of your toolbag when in a scrapyard.. They keep jumping into my bag
Get several from the same type of car, you will probably get a good one amongst them. If not you can always buy a new one later!
Best Regards
Geoff
http://www.v8viento.co.uk
