Author: Subject: Mounting the VR sensor on a X-flow?
David Jenkins
posted on 9/11/06 at 08:00 AM Reply With Quote
I'm looking for a few bright ideas for mounting the VR sensor on a x-flow... don't seem to be many obvious 'spare' bolts available for use.
Any photos of your installations would be much appreciated, to get the creative processes working.
cheers,
nib1980
posted on 9/11/06 at 08:18 AM Reply With Quote
Check in Paul F's gallery good pictures and easy to view, he, like me has used the cam cover bolts to mount there VR sensor holder. If you want I can try and post some picture in my archive tonight?
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=DSCF0066.JPG
[Edited on 9/11/06 by nib1980]
viatron
posted on 9/11/06 at 09:04 AM Reply With Quote
we used a piece of aluminium angle bolted between the long common timg chain cover / water pump bolt and one other timing chain cover bolt, took minutes and has lasted fine just use beefy angle.
Mac
posted on 9/11/06 at 09:41 AM Reply With Quote
How did you mount the toothed wheel to the pulley? Been thinking about a spacer between and welding? PS sorry to high jack thread
David Jenkins
posted on 9/11/06 at 04:19 PM Reply With Quote
Shan't forgive you!
Any more pictures, anyone?
CairB
posted on 9/11/06 at 05:06 PM Reply With Quote
David,
If it is any help, heres a picture of how I did a quick knock up on a pinto.
Please exuse the brown stains
Colin
MegaSquirtnEDIS - VR sensor & disc
[Edited on 9/11/06 by CairB]
David Jenkins
posted on 25/11/06 at 04:00 PM Reply With Quote
OK - got everything set up, took all the bits off etc. - and in all the heaps of metal off-cuts I've got, can I find a 150mm length of 3mm ali strip? Can I b*ggery!
Never mind - I've got to order some slightly longer bolts anyway...
One consolation - at least I've started, and this is the most fiddly part of the Megajolt installation. The rest is just wiring (and I like doing that bit).
David Jenkins
posted on 28/11/06 at 07:17 PM Reply With Quote
BUGGERIT!!!
Pride goeth before a fall...
Made the bracket, it lines up nicely with the toothed wheel at JUST the right spacing, and it looks really smart in its new coat of paint...
Went to re-assemble everything and - found that the VR sensor wants to share the same bit of space as the edge of the fan belt! Buggerit!
Still, what doesn't kill us makes us stronger... definitely a learning experience...
Back to the drawing board.
scutter
posted on 15/12/06 at 03:26 PM Reply With Quote
CairB, Is that peice of steel thick enough for the VR sensor to pick up?
If so i'll get on and make mine.
Cheers Dan.
CairB
posted on 15/12/06 at 04:07 PM Reply With Quote
Dan,
It seemed to be, I made it out of 16's gauge with the missing tooth bent back.
It was a lash up as I was only getting confident with the MS before my engine swap.
The toothed wheel was already fitted on the new engine.
From memory it isn't much thicker.
There is a drawing of it in my photos if its any use.
I made it by drilling then snipping the disc to the drilled holes.
At that radius you can achieve a reasonable degree (no pun intended ) of accuracy.
Have you looked at buying one off ebay tho'?
Colin
scutter
posted on 15/12/06 at 04:47 PM Reply With Quote
Colin, I've one off Ebay but the diameter is too big, (I'll use it on the V8) I need a smaller diameter as i've got an alloy front pulley
I've some 3mm steel i'll use for the crossflow
ATB Dan.
