tks
posted on 17/1/07 at 09:15 AM |
Power Commander || Adaptation
Guys,
what happens if you select a file wich isn´t for your powercommander/bike.
Are you able to upload it?
Or should we just see it as a file wich a name what i mean to say no control is done for what powercommander it is.
Are you able to open a honda map? and load it into the R1??
reason i ask is on fleebay there are allot of Powercommanders some cheap some not so i just wanted to adapt it to my own bike. should be quet easy!
Tks
p.d. take in mind that many bike share coils, temp sensors etc..
The above comments are always meant to be from the above persons perspective.
Hellfire
posted on 17/1/07 at 09:31 AM |
In theory - I would say yes you can upload whatever file you want. But I doubt the bike original ECU could be modified by the Power Commander to give
the correct running conditions you require.
tks
posted on 17/1/07 at 10:04 AM |
you are wrong :D
The power commander doesn´t change the stock mcu. it just adds or cuts time to the injection event.
For the spark it could do the same.
in fact if you have 4 coild and 4 injectors you only need 8 inputs and 8 outputs..
Tks
