Author: Subject: Sealing a filler hose connection
RazMan
posted on 28/1/07 at 01:03 PM Reply With Quote
My fuel tanks have 50mm straight filler spigots (without the normal beading) and I am finding them a bugger to make a good seal to the filler hose with jubilee clips.
Bearing in mind that welding on a bead is not an option, what can I do to improve the seal?
Raz
mark chandler
posted on 28/1/07 at 02:18 PM Reply With Quote
You could try making an epoxy resin bead.
Just work soem resin into some thin string and take a couple of turns around the tube.
stevec
posted on 28/1/07 at 04:33 PM Reply With Quote
I have used these type they work a treat.
Steve,
RS number 526-5549
[Edited on 28/1/07 by stevec]
RazMan
posted on 28/1/07 at 04:42 PM Reply With Quote
Mark - The fillers are in an awkward position so access would be tricky to say the least. Nice idea though
Steve - Coincidentally I have just found these myself on eBay. All stainless and less than £3 each too!
eBay
Raz
