Author: Subject: Ford crank position sensor connector
r1_pete
posted on 31/5/07 at 07:49 AM Reply With Quote
Anyone know a supplier of replacement connectors for the Ford Crank Sensor (Zetec etc.) is the Junior power connector from Vehicle Wiring Prducts the one?
Cheers.
Pete.
scottc
posted on 31/5/07 at 09:38 AM Reply With Quote
http://www.trigger-wheels.com/electrical.php
£2.59
David Jenkins
posted on 31/5/07 at 09:48 AM Reply With Quote
The trigger-wheels one does work, but has just one drawback - there's no quick release, as found on the original Ford item. You have to faff around with the spring if you want to take it off again.
Otherwise, it does do the job.
paulf
posted on 31/5/07 at 10:31 AM Reply With Quote
It is a junior power timer plug the same as a lot of injectors etc.
Paul
r1_pete
posted on 1/6/07 at 11:14 AM Reply With Quote
Thanks everyone, can get the bits ordered in and the loom built now...
