Author: Subject: its official "its a runner"
tim windmill
posted on 13/9/07 at 08:34 PM Reply With Quote
finally got the car running today after all my megasquirt woes. Big thanks to Rayward "megasquirt god" for all his help and patience. We never got to find what the problem was with the coil drivers so now running with the edis set up, engine ran and ticked over first turn of the key. Now the real fun starts with the tuning
MkIndy7
posted on 13/9/07 at 08:38 PM Reply With Quote
Wohoooooooooooo..
Does the Ignition andvance etc work like that or is it just running in Limp home mode?
roadrunner
posted on 13/9/07 at 08:44 PM Reply With Quote
I bet your well chuffed.
tim windmill
posted on 13/9/07 at 08:48 PM Reply With Quote
yes ignition advance works ok just as it should. Ray altered the set up of the megasquirt to run the edis instead of the coil drivers,so now i have the safety net of limp home mode. The only issues that i have at the moment is that the fuel pump does not shut off if the ignition is left on with the engine not running. so we have still got that to sort. definate progress
jacko
posted on 13/9/07 at 08:49 PM Reply With Quote
About time Well done to you and Ray
Graham
tim windmill
posted on 13/9/07 at 08:50 PM Reply With Quote
hi roadrunner well chuffed now
MkIndy7
posted on 13/9/07 at 08:52 PM Reply With Quote
Hmm that is a Strange one, that must be something internal to the Megasquirt that keeps it running.
I wonder if any of the pins, wires in the plug or circuits are close together and the 2 faults are related.
tim windmill
posted on 13/9/07 at 08:57 PM Reply With Quote
Ray is going to build up another megasquirt and we are going to swap the units and see if this cures the problem, but at least it will run for now
Fatboy Dave
posted on 13/9/07 at 10:37 PM Reply With Quote
Where did you get the suspect MS? Bill Shurvinton will diagnose most units if you drop him a line if there is any suspicion that yours is duff...
Dave
Stop the planet, I want to get off
