Author: Subject: what size fuel pump?
rumplitter
posted on 29/1/08 at 02:10 PM Reply With Quote
I'm running a mid engined B18C4 Honda Vtec engine, approx 200BHP+
370cc injectors
what size fuel pump should i use?
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
JAG
posted on 29/1/08 at 03:24 PM Reply With Quote
You'll need about 65 Litres per hour (that's 15 Gallons per hour) for 200bhp.
That's at 43 psi or 3 bar.
If you sized your pump, say 20% bigger, then I would think you'll be fine.
Obviously talk to the pump manufacturer about how much oversize you should make it.
[Edited on 29/1/08 by JAG]
Justin
posted on 29/1/08 at 04:18 PM Reply With Quote
Make sure you've got a goodly % excess on the pump. You really don't want to run out of pump power and therefore your nice engine suddenly running lean when you're revving the nuts off it!!!
atomic
posted on 3/3/08 at 11:43 AM Reply With Quote
Best bet would be a Bosch 044.
I run one of these to feed my F20C (S2000) engine.
You can pick them up new from ebay for about £120-130 much cheaper than rrp.
