Author: Subject: Wideband Sensor With Megasquirt
MKMike
posted on 22/2/08 at 10:38 AM Reply With Quote
Do I need a wideband controller or just a sensor with a megasquirt ecu.
Will this one work?
Link
paulf
posted on 22/2/08 at 11:32 AM Reply With Quote
Yes you do need a controller , that one would work but most people use the innovate LC1 which i think may be cheaper.
Paul.
ed_crouch
posted on 22/2/08 at 01:22 PM Reply With Quote
Yep, the MS system was designed to interface to a narrowband sensor, which basically just swings a voltage one way or the other to say rich or lean. The wideband controller goes in the middle, between the MS and the lambda probe, and will output a precise voltage around the stoich voltage of a narrowband sensor, allowing MS to discern HOW rich or HOW lean the engine is running.
the Wideband controller plugs into a wideband sensor, which has a nice linear (ish) characteristic. It also does something terribly technical with something called a Nernst cell, and it runs a heater to keep the sensor up in its operational temperature regime.
Ed.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
MKMike
posted on 22/2/08 at 05:14 PM Reply With Quote
How about this one, will it work with Megasquirt?
Link
MikeRJ
posted on 22/2/08 at 06:45 PM Reply With Quote
That has a 0-5v linear output so it should work fine with Megasquirt. It's a very good price too, if you can avoid customs...
http://www.plxdevices.com/products/sm/afr/
[Edited on 22/2/08 by MikeRJ]
MikeRJ
posted on 24/2/08 at 11:28 PM Reply With Quote
Yes, the MS Lambda input is compatible with either a narrow band sensor, or the output from a wideband controller.
violentblue
posted on 25/2/08 at 01:09 AM Reply With Quote
I just built my megasquirt, and reflashed it for S&S-E, I'm also using the innovate LC1.
I like the fact that megasquirt is preprogrammed to use the LC1
a few pics of my other projects
