Author: Subject: ms map for injected pinto
joscorstjens
posted on 17/3/08 at 11:37 PM Reply With Quote
Hi,
I'm going to install a megasquirt on my injected 2.0 Pinto because the belgian 'sva' wants me to have lambda control. So I'm looking for the following info:
- flow rate of the injectors
- is the actual 6.3ohms of my injectors to be considered as high-impdedance or low-impedance .. as it's right in the middle of 3 (lo) and 10 (hi)
- resistance values at several temperatures of the air and water temperature sensors
- if possible: basemaps
tia
jos
vinny1275
posted on 18/3/08 at 08:07 AM Reply With Quote
Hi Jos,
I've been looking for basemaps for my Pinto for a while and not found any. You're welcome to have mine when I've got the engine running (*hopefully* about a month away).
Are you using the standard Ford EFI unit, or something more exotic?
Vince
John.Taylor
posted on 18/3/08 at 01:15 PM Reply With Quote
Is there any chance that I could get the base maps too? I'm looking to SVA in August and Megasquirt my 2.0i Pinto over winter.
joscorstjens
posted on 18/3/08 at 10:58 PM Reply With Quote
Right now, the engine is running well on the original Ford Ecu ... which is lacking lambda controll.
