thunderace
posted on 1/7/08 at 08:54 PM |
fuel pipe leak audi A6 1996
hi guys my mate has a pin whole leak in a solid fuel line
is there an easy fix
its spurting like a mini jetwash.
Mark G
posted on 1/7/08 at 08:59 PM |
No.
Where fuel is concerned spend the money and replace the pipe.
MkIndy7
posted on 1/7/08 at 09:09 PM |
A very quick temporary fix might be a patch of fuel safe rubber under a suitible size jubilee clip tightened down where its leaking from.
If its a standard plumbing size I'd see no problem with cutting it and putting a compression socket in there.
You could even cut the section out and join it with some flexible correctly rated Fuel pipe with a fuel pipe clip on either end.
bigrich
posted on 1/7/08 at 09:11 PM |
cut it and join with a piece of rubber fuel hose and suitable clips, no worse than the link between the rigid line and fuel rail
